1 - 4 of 4 Posts
What products do you use to clean your chain? My mechanic said not to use kerosene (like was said in other posts) so what should i use?
what product should i use to lube it up with?
thanks for the help.
looking for more curves
If you do not use kerosene, then I have no idea.
For lubing I use Bell-Ray chain lube (not sure if that is was it is called).... I think if you use any kind of chain lube you'd be ok.
where does one go to buy kerosene???
Banned
actually if u read your manual it recommends kerosene to clean it with. but alot of people use WD40 to clean it and then a good spray on wax lube.
jasamb u can get kerosene at your local hardware store and actually at a few gas stations, but not many :cheers
1 - 4 of 4 Posts
