Hi guys. I've just bought the a 2018 r6. The problem i have is that the biting point is right at the end just before I've completely released the clutch. It also has quite a clunk when engaging into 1st from neutral, I believe this is becouse of the biting point.
I've tried the cable at the clutch lever but failed as it remains the same! Any suggestions?? Thanks
YZFR6... ooodles of HP
The clunk is worse on cold startup. So I start her in gear already to not do it. Once warm, a slight clunk can occur, but shifting to first a foot of tire roll before you dead stop will eliminate that as well.
Would also like to see good suggestions
