21 - 27 of 27 Posts
2009 Yamaha YZF R6S
Discussion Starter #21
I guarantee they are not tight enough if you stopped when the clutch started turning in nuetral. They will back out and do far more damage than a $20 torque wrench! You need to take the cover back off and torque them down. The specified torque is 5.8 lb-ft. That’s about 2 fingers tight on a 1/4 inch drive ratchet. And they should be tightened in stages in a crisscross pattern. I still say go to AutoZone and borrow 1/4 inch drive torque wrench. Yeah, you have to put money down on a card, but they give it back when you return the tool.
how much damage was done to the threads on the sprocket nut? All of this may be pointless if the sprocket threads are messed up and you can’t get the sprocket nut to tighten (oh, and that’ll need blue locktite)
376361
2009 Yamaha YZF R6S
Discussion Starter #22
376362
this is the piece that moves when i tighten it. your saying this isnt supposed to rotate when its in gear? i put it in 1st gear and it still spins. its hard to spin it but i mean it still turns if i apply pressure. that always spins tho so should i hold it by hand until the torque wrench clicks?
UR B-hind Da 8 Ball
You need to connect the sprocket and chain to the rear wheel. When that turns, the sprocket turns. With the chain attached to the rear wheel and the rear wheel on the ground, it will keep the clutch from spinning.
UR B-hind Da 8 Ball
And BTW, those threads on your output shaft look bad. I don’t think you’ll be able to get the sprocket nut to tighten up. If not, you are going to be in for making a really expensive decision, or jury rigging it in a way I won’t advise on.
2009 Yamaha YZF R6S
Discussion Starter #25
mannnn :(( what if i try to slowly rethread them by forcing the nut in the right way.
i can also weld. maybe i can just tac the corners so it’ll hold. so whenever i swap it out, i can just sand the tacs off
Dude, you might be in over your head!
You can download the manual here:
Once again, you need the 03-04 manual.
Sadly those links to the Service Manuals no longer work
And I was so hoping to find a service manual for the 03-04
UR B-hind Da 8 Ball
They are in the R6-forum Facebook group page under the files tab. And on the “R6 Gen Two (03-05, and 06-09 R6S)” Facebook group page
21 - 27 of 27 Posts
