1 - 2 of 2 Posts
ahh ha ha (mandark laugh)
I took a low speed fall on the right side back in Oct, since then I cant get the clutch to disengage. I can pull the clutch lever all the way in but the bike still clunks and dies when I drop down into first. I searched a few threads and checked that the arrow and dot were in line on the clutch cover and they were. Also read that the lever might be out of whack, how do I adjust the lever? If that doesn't work can anyone point me in the direction of what to check next? T.I.A.
Banned
are you sure it's the clutch and not the kickstand switch killing the engine?
you can unplug it and jump the wires to bypass the switch.
this is how racers set theirs up to remove the kickstand.
unless you had the clutch apart for some reason and you know for sure it's the clutch, I'd start checking other things.
like one, you can put your bike on a stand and put it in gear with the wheel off the ground, if it doesn't stall, then I think it's safe to say the clutch is the problem.
1 - 2 of 2 Posts
