1 - 5 of 5 Posts
Installed translogic QS and it ran good for a couple of days, then after a few rides code 33 comes up and bike won’t start what should I do?
Hi there,
Re-check what you did :)
You must have left something disconnected , or it was connected, but not properly, and eventually came off?
Fault Code: 33
Symptom: Open circuit is detected in the primary lead of the ignition coil (# 1, #4).
Probable cause of malfunction:
Open circuit inin wiring harness
Malfunction in ignition coil.
Malfunction in ECU.
Malfunction in a component of ignition cut-off circuit system.
Hi there,
Fault Code: 33
Malfunction in ECU.
Thank you got in there checked everything and yes the connection to the coil the wire was rubbing against the fan and both wires were touching quick fix with electrical tape thankfully the QS wire was not damage
1 - 5 of 5 Posts
