1 - 5 of 5 Posts
I think my bike rides me?
I found three links for codes on this forum.
I think this is for 04? can some one confirm cause the guy posted in 2004.
http://www.r6-forum.com/forums/showthread.php?t=10872
11 Cylinder identification sensor failure
12 Crankshaft position sensor failure
13 Intake pressure sensor failure
14 Intake pressure sensor pipeline failure
15 Throttle position sensor wire disconnected or short-circuited
16 Throttle position sensor stuck
21 Water temperature sensor failure
22 Intake temperature sensor failure
23 Atmospheric pressure sensor failure
24 Oxygen sensor failure
30 Lean angle cut-off switch activated
31 Maximum allowable Oxygen sensor correction level exceeded
32 Oxygen sensor correction level too low
41 Lean angle cut-off switch disconnected or short-circuited
42 Vehicle speed sensor or neutral switch failure
43 Monitor voltage -- less than 3v
44 ECU failure
and this was put out on last week so not sure what year bike this is for
http://www.r6-forum.com/forums/showpost.php?p=2489436
01 - TVS signal, 12-21 - 97-106
02 - Atmospheric Pressure
03 - Intake Air Pressure
05 - Intake Air Temperature
06 - Coolant Temperature
07 - Vehicle Speed Pulse
08 - Lean Angle Sensor, 0.4-1.4 Upright, 3.7-4.4 Overturned
09 - Fuel System Voltage
13 - TVS Signal 2, 9-23 - 94-106
14 - TPS Signal, 12-22 - 97-107
15 - TPS Signal 2, 10-24 - 95-109
20 - Kickstand Switch
21 - Neutral Switch
30 - Coil #1
31 - Coil #2
32 - Coil #3
33 - Coil #4
36 - Primary Injector #1
37 - Primary Injector #2
38 - Primary Injector #3
39 - Primary Injector #4
40 - Secondary Injector #1
41 - Secondary Injector #2
42 - Secondary Injector #3
43 - Secondary Injector #4
48 - Air Induction Solenoid
50 - Fuel Injection Relay
51 - Radiator Fan Motor Relay
52 - Headlight Relay
53 - EXUP Servo
60 - EE Prom Fault Cylinder Number
61 - Code History, Codes will cycle every two seconds if more than one.
62 - Erase Codes
63 - Code Reinstate
70 - Control Number
I have a code 20 on my 06. trying to find what it means.
O wait just found this page as well. is this page for all years the same?
http://www.r6-forum.com/forums/showpost.php?p=2489437
Fault Codes
11 - Cylinder Identification Sensor
12 - Crankshaft Position Sensor
13 - Intake Air Pressure Sensor open or short circuit
14 - Intake Air Pressure Sensor hose system malfunction
15 - Throttle Valve Sensor open or short circuit
17 - EXUP Servo motor open or short circuit
18 - EXUP Servo motor stuck
19 - Kick stand switch open or short circuit
20 - Atmospheric Pressure Sensor and Intake Pressure Sensor voltage differ greatly
21 - Coolant Temperature Sensor open or short circuit
22 - Air Temperature Sensor open or short circuit
23 - Atmospheric Pressure Sensor open or short circuit
24 - O2 Sensor Signal
30 - Lean Angle Sensor
33 - Coil #1 open or short circuit
34 - Coil #2 open or short circuit
35 - Coil #3 open or short circuit
36 - Coil #4 open or short circuit
39 - Open or Short circuit in primary injector
40 - Open or Short circuit in secondary injector
41 - Lean Angle Sensor open or short circuit
42 - Speed Sensor, or Neutral Switch
43 - Power Supply to Injectors and Fuel Pump
44 - Error with ECU PROM
46 - Charging System
50 - Faulty ECM Memory
59 - Throttle Position Sensor open or short circuit
60 - Throttle Servo motor open or short circuit
Er-1 - No ECU Signal
Er-2 - No ECU Signal
Er-3 - Data from ECU not received correctly
Er-4 - Non-registered data received from mete
1 - 5 of 5 Posts
