08 R6 with 20,000k on it. ECU flashed a month or 2 ago. A cold start the bike idles a little off and would shut off wit the smallest amount of throttle(before ECU flash). I got ECU flashed and problem went away. I made a manometer, tried to sync throttle, adjusted cylinder 3 and 4 and nothing happened. Cylinder 3 and 4 are .5 turn out from all way in, I continued to adjust screws then check engine light came on. I put cylinder 3 and 4 back to what I thought was normal, shut bike off, turned bike on and light was off.
Now the cold start issue is back, idles little off, shuts off wit tiny throttle and idles fine after 15 to 20 seconds and throttle response is normal.
Any ideas?
Adjustment screws not back to normal spot???
Thank u
Any ideas?
Thank u
