· Vendor
Rhino adjustable clip-ons from ConvertiBARS provide serious adjustability for the rider that requires a degree-perfect fit. Manufactured from 6061-T6 CNC-machined aluminum and assembled with high-quality stainless steel hardware, Rhino clip-ons have been tested by ConvertiBARS to withstand the rigors of the road and track with the added versatility of adjustable-angle handlebars. To adjust the downward angle of the handlebar, simply loosen the collet located in the fork clamp assembly, index the handlebar to the desired angle and re-tighten everything as specified. The Rhino allows a bar angle of -8, -4, 0, 4 & 8 degrees – covering a wide range of preferences. Furthermore, the bars are pre-drilled in several places to permit easy installation of OEM controls, thereby negating any need to hatch or drill the bars or remove the locating tab on the switchgear of most late-model sportbikes.
ConvertiBARS Rhino clip-ons are available to fit 41, 43 and 50mm diameter fork tubes. Call TJ at 866.931.6644 ext 817 to order. You can also email us with any questions you may have – send those to FORUM at RIDERSDISCOUNT dot COM with RHINO CLIP-ONS in the subject line along with the size you need and we’ll get back to you fast.
ConvertiBARS adjustable clip-on kits come with everything you see here. Clear instructions - both printed and on CD-ROM, stickers and even a brake reservoir mounting bracket.
Here you can see the collet mechanism which provides a solid feel when assembled correctly. ConvertiBARS have tested their clip-ons to withstand up to 800lbs of force, much greater than that which would be expected under normal riding conditions. Bending, not breakage, occurred at 1000lbs of force!
As mentioned, each handlebar is predrilled to allow the installation of OEM switchgear without the need to remove positioning pins, or drill holes in the clip-on.
ConvertiBARS are available in black or silver finishes and replacement bars are also available.
Don’t forget to ask for a set of grips when ordering!
