1 - 7 of 7 Posts
So I dropped my r6 and the crank case cover is cracked witch makes it leak oil would I just need to get a case for it or a entire module
377371
Super Moderator
Get the case cover and the gasket. Check out www.partshark.com for great oem prices.
2009 YZF-R6
We'll that's your timing cover, lots of places online call it an oil pump cover.? Just make sure you get one for the correct year. The gasket goes between that cover and the crank case.
Be careful, the bent and missing bolts in you picture could have cracked your lower crank case, big $$$ to fix. You may also need a new clutch cable bracket. Also get yourself some good frame sliders to save this stuff moving forward. Good luck!
As Richard pointed out, that cover and gasket won't do you any good if the bottom crank case is damaged to the point that it won't allow a seal. Figure out whether any replacement can be bolted at the bottom, figure out whether there are any hairline fractures first, BEFORE ordering any parts.
1 - 7 of 7 Posts
