1 - 5 of 5 Posts
This is probably a dumb question, but i'm VERY VERY new to motorcycles...well.. there inner workings.
...I got a pretty decent scrape on my crankcase (left side) and was going to replace it. If i just remove the crankcase cover do i have to drain the oil out of the engine? - is there oil directly behind the crankcase cover? I am planning on just replacing the cover.
If not, i'm just going to spray it with high-temp paint.
Team: Teletubby racing
there is defiantly oil in the crankcase...make sure you drain your oil first.
do what i did, and use a sharpe marker to cover it up :)
Discussion Starter #4
i just sprayed it with flat hightemp black paint.. looks perfect. I'll put a new one on when i change my oil next. I just changed it for the 1st time yesterday.... 1300miles....
good boy, make sure the filter is on tight...you wouldn't want to go down on your own oil
1 - 5 of 5 Posts
