1 - 11 of 11 Posts
Whatever happens, happens
So I installed the TST integrated tail light and flush mount blinkers yesterday. I didn't install the load resistors because I didn't want to cut any wires, but do I actually need them?
After the install the blink speed looked fine to me. So is there any negative affects if I leave them out?
I have a 2014 if that matters.
nup, only thing they will do is burn out quicker. Though relay is literally a 2 minute install (unplug, plug in) under the seat
But that's if it blinks too fast correct? Mine blink the same speed as stock.
Hello
you will if the laws in your area state that turn signals must flash at a particular rate. And as stated, remove the seat and it switches out easily enough. Its worth it.
R6 noob
Who makes and sells this resistor/relay? I need it for 2004 R6 with hyper blinking syndrome :( And just plug and play correct? I got LEDs front and back if that makes any difference.
R6 noob
Ended up ordering the TST Industries Gen 2 LED flasher relay. Only $18.50 +shipping and it covers all 4 of my signals plus it has an adjustable flash rate.
1 - 11 of 11 Posts
