Has the cat and all material inside the header removed for a str8 through pipe.What is having your headers punched out?
There is a post in the How-To about this. You need to install/make smog block off plates and remove your air pump. That is the primary cause of popping/cracking in the exhaust.bike runs fine just cracks up some mike at mjsperformance recommended that i get an aftermarket filter which i just got yesterday so i will install and let you guys know if it made a difference
