1 - 20 of 33 Posts
Just wanted to get some input on how to correctly drill through my left fairing for a frame slider for my 2000 r6. I already have one on the right but that was already on when i bought the bike. Now i have to put the left one on. How should i mark the fairing accurately enough to know where to drill? And, what kind of drill should i use? Also, what bit should i use?
I heard that i'm supposed to use a drill that has very high rpm's. somthing like a air compressor drill.
ok your going need need a whole saw I would say 1/16 bigger then the dia. of your fram slider.
put masking tape over the area on the side your going to drill so you dont get chips in the glass
drill a pilot hole so the hole saw dosnt jump all over the place then drill
I didn't put mine on but i say take off the fairing and put the slider on and see where it hits fairing on the inside, mark it off and cut. be careful though. I used a the drill with large teeth to cut the hole for my flushmount turnsignals and the edge came out somewhat jagged or not as clean as i wish it was. So see if you can get a drill bit with fine edged teeth.
Dont take my word for it though consult with a shop and see what they do.
take off the fairing and put play-doh or clay or something on the inside, then put it back on and push it so the engine mount bolt makes a mark. then take it off and put a point in the middle of the mark, and drill from there! good luck
To find the correct holesaw size take your slider to shop garage etc and slide it into the holesaw. It should just fit. Be careful not to scratchup your new sliders on the teeth. This should give you a good clearance all round the slider. Now just get the hole exactly centered. Paint up the cut edge with some touch-up paint or it looks very backyard.
heebiedabajeebies!
Jimbo, i got the same sliders too (Shogun no frame modification), i got them on Ebay as well. Put them on 3 weeks ago.
Have you ever had to put the mto use? i am hoping you haven't but if you did, how did they fare?
I heard that the aluminum offset may bent when bike is dropped on its side. I hope this isn;t true for the Shogun. They seems to be well built.
Mike
1 - 20 of 33 Posts
