1 - 4 of 4 Posts
Some background:
01 YZF-R6, Ivan's jet kit, Yoshi exhaust
The other weekend we jetted a friend's R6 and now he's got issues after 12k in either 5-6th. It acts like it just runs out of power. If he pulls in the clutch it dies. 1-3 to red line no issues. During the jetting one of the air jets broke off in the carb. We were able to find another carb pack. We took the bad one off and swapped in the proper one. It's number 4 with the TPS. We ended up using it's TPS as we found them to be slightly different. We also found the carb to be slightly different so it's a different year. We synced the carbs and all was well. Well he needed a new battery as well. He got one and popped it in. We've already had to charge it once though. He's getting it load tested as he's charging properly.
On the bowl, of the carb, are little flat blade screws. They only go a couple turns either direction. We can't seem to find what these adjust. Anyone got any ideas as to what they are or what the issues could be?
But looking at your plugs can give you clues as to whether you need to enrich or lean it.
1 - 4 of 4 Posts
