easiest way to bring forks up?
1K views 4 replies 3 participants last post by  8Ball
#1 ·
when i bought my bike it had the soupys lowering kit on it and the front triple tree was lowered, forks almost two inches through the top clamp. what is my easiest way on putting the forks back to stock height? i already took the soupys lowering links off and put the stock ones back on, already rides alot better
#5 ·
If you have a rear stand, put it on that. Use a floor jack with a 1X3 board under the headers. Raise the jack enough to get the weight off the front wheel and loosen the bolts on the triple clamps and the clip-ons. You can use the floor jack to help set the height.
If you don't have a rear stand, you can do it on the kickstand, but it will be sketchy.
