1 - 11 of 11 Posts
do u even lean
stupid question....... I have a power commander 5 and also had my bike tuned. so the question is if at all possible will a flash ecu work with the power commender or is it pretty much the same thing .
thank u in advance for the people for your help..
Mr. HER6
Yes you can have both. The PC only modifies the fuel map, and since you already have a good map in it you can continue to use that. A good flash has several other benefits and you can add that while leaving the default fuel map in the ecu.
do u even lean
thank u.
any recommendations on where to get my ecu flashed.
Go with chief if ur gonna do it great customer service
The timing changes done with an ECU flash, might require a revised map in the PC V. More advanced ignition timings will start the fuel burn sooner, and it could need more fuel than the current map will be giving it. Autotune can be used to adjust the fuel map to where it's needed.
1 - 11 of 11 Posts
