Hi,
I am really hoping you can help me!
I have a 2006 Yamaha YZF R6.
Problems started just over a momth ago. The bike would start bogging down, misfiring, sounded awful and would not go above 35-40mph.
If you tried to push past this speed the whole bike would start rocking back and forth quite violently.
I changed the spark plugs, took the bike out, it flew for 20 minutes and then the old problems came back.
I then did some reserach and it pointed towards an ignition coil problem. So all four coil packs were changed, again took the bike out, this time it sounded a bit off from
the start, 10 minutes down the road the engine management light came on and then the bike cut out completely. Fault codes 35 and 36 were flashing on the dash.
Bike wouldnt start so a mate had to come pick me up in his van.
Fault codes 35 and 36 are an open circuit on ignition coils #3 and #4. Swapped all the coil packs around to see if it was a coil issue and it didnt matter what way round I had
them still got the same fault codes. So coil packs are fine.
Further research then pointed to a faulty ECU. I found a secondhand one and tried it on the bike, this ECU cleared the fault codes, but the bike would only crank, not fire.
Seems to be this ECU just isnt communicating with the bike or is faulty also.
There is fuel, spark and compression, so the issue is electrical. Put the old ECU back in and it did the same thing with fault codes
All wires have been checked and are ok.
I am honestly at the end of my tether now, I believe the issue is an ECU problem, but finding a second hand ECU for this bike is seemingly impossible.
Please, if anyone can help, any ideas on what the problem is or anywhere I can get an ECU. I have checked breakers yards and ebay many times.
Thanks
Thanks
