So I just installed some flush mounts in the front (actually just the left side so far). The flush mount only has two wires so I just taped off the running light wire. I also have an integrator in the back with resistors. When I started it the headlight does not turn on but everything else does (including the small light in the front between the actual headlights and both front and back signals). Any ideas?
