1 - 4 of 4 Posts
I laid my 04 over and cracked the stator cover and damaged the stator. So i replaced both and its bogging bad and the check engine light comes on when i ride it then will die then won't start. Could this be the solenoid for the stator?
You replaced the stator? I ask because my bike was doing the EXACT same thing, bike seem to be running fine the check engine light would come on, and not to long after my bike would die and wouldn't start back up even push starting. So i dropped it off at the dealership last week and they said the stator was bad so they're replacing it now... thank God for the extended warranty!
Does the tach and speedo ever cut off while riding? I was just reading a different thread where the guy's check engine light would come on then, the speedo tach would cut off, and eventually the bike would shut off... He said it ended up being the regulator... might wanna try that if it has any of those symptoms.
1 - 4 of 4 Posts
