1 - 17 of 17 Posts
· Newb On A Mission!
okok... hoping I didnt buy a bad bike... i trusted the seller and like him, so i think thats not the case. lol
But... heres the new issue..
upon heavy breaking from decent speeds... the engine shuts off... and at a normal idle.. it seems real low of an idle..
any idea whats going on?
i have pc3, exhaust, bmc street filter, and running mobile 1 oil.. fresh! lmao
did you ever get your other problem fixed with the headlights killing the battery?
ya. i was told the high beams were drawing to much power. cause all 4 bulbs came on when highs were turned on..
so im getting hid, and just not using the highs until i wire a cut off for the lows when i switch the highs on. lol
i dont need 4 bubs on at a time.
All 4 bulbs should be on when you use your high beams.. I run my high beams (which uses all 4 bulbs) all day long everytime I ride. I don't get battery draining issues.
Your idle may be too low and when dropping from a high rpm too fast it may stall. Or you might not be pulling in the clutch fast enough or all the way.
· Mr. B (Florida Boy)
Lol, I was gonna say vacuum problem...but I forgot i'm not on my Z forums anymore :*tongue
it starts fine. and runs great plenty of juice in the battery. its a new battery.
Hmmmm, maybe an exhaust leak somewhere and when you decel the back pressure is effed up?:confused:
im thinking its the plugs. im at 16k miles and i don't think the previous owner changed the plugs
Damn son. Even if it's not the plugs change them out. 16k is a lot for originals!
Would hate to hear that the ceramic shield broke apart and ****ed your shit up!
called the previous owner, they were changed. And i got my problem fixed. It was my valve pressure, the screw was coming loose overtime. raised my idl back up to 1.3k and now it starts and runs perfectly fine.
· DARC Racing
Do you have the clutch pulled in or not? If you have the clutch pulled in, your rpm's are down...... (related to low idle) This model has a common low idle and even stalling out.. so if you have the clutch in, your RPM's are at idle levels.....
Since you have a PCIII this is an easy fix.... (both issues will resolve with same fix)
I had the same issue with stalling (but I dont have the clutch pulled in on hard breaking so not the same for me there) but I pull the clutch in when coming to a normal stop and then it would stall on me.....
The RPM's under 3K need to be leaned out a hair.. Any good tuner shop should be able to do this for you... If you know enough of how to use your PC software you can hook up to a PC and do it yourself... but you need only to lean it out a bit... Simply take all settings for the RPM's under 3K and lean them out 1 digit at a time until the issue is solved.....
This solved my low idle prob and my stalling out problem when coming to a normal stop (with clutch pulled in, I never had the problem while hard breaking and clutch level not pulled in).......
1 - 17 of 17 Posts
