So obviously a quick search reveals that 41 is lean sensor.
I've tried gluing the sensor and l've also tried the known working sensor from my 13S R6. Neither has brought me any joy.
And l also cannot delete the code in diagnostic mode. I think it's just running the fuel pump when l turn the kill switch on.
Apparently it just stopped working one day, but l'm only taking the seller on his word. He said that the ECU has been changed, l have a spare barrel, key and ECU as well as the ones installed. And just to complicate things further, the tank key matches one barrel, the other obviously doesn't and l can't unlock the pillion seat!
I've also tried swapping the ECU over, but all l got was 52 and l couldn't get into diag mode. I didn't try the other barrel
Has anyone got any suggestions on what else it could be, what to try? I have got my 08' R6 that's in very good condition l can take parts off to try and eliminate the problem/s, but l don't want to go too wild if it can be helped.
