2005 R6 with about 68xx miles, everything on the bike works EXCEPT the tachometer.
ok this is what I've done so far with no type of success, the tachometer needle stays on zero forever.
bought a used tach to switch and same results: the second tach stays on zero.
bought a used ECU from the same person: the second ECU did nothing, tach stays on zero.
change spark plugs just to try anything, the tach stays on zero.
change the front sub harness (connects to the lights and tachometer) result: the tach stays on zero.
change the sub harness that connects to the coils, the tach stays on zero.
change the rectifier, the tach stays on zero.
what the hell? The only thing that I have NOT done is change out the entire wiring harness. The only time the tach needle sometimes works is when I hit a bump during the ride. The tach starts to work during that ride session.
Tach sometimes work the next day after the ride but that is so rare.
Anybody else heard of this problem?
Any ideas on what the fix is or any bulletins out there for this issue?
If I take it to a dealer do they diagnose the problem for a fee or for free? What is this diagnosis fee? I'm about throw in the towel and let the dealer have a crack at this. Will they tell me 'this is the problem and this is how much it will cost you to fix' ? Is the work guarantee in other words if the same tachometer problem creeps up again will they fix it for what I already paid or is it a new repair fee all together? :comp
