1 - 5 of 5 Posts
LHRB
Received this today. Looks nice. Pics and review to follow install.
LHRB
Discussion Starter #2
Bit of a bummer.
First thing I discovered is that this unit does not fit the ABS models without modification.
The top tabs used to clip on to the radiator will need to be cut off in order to squeeze the screen behind the ABS plumbing (in red on the attachment below). I will trim off those tabs and it should have the required clearance to squeeze by the brake plumbing.
Once in place I will use zip ties to secure the top of the guard to the radiator, as is done with cox guards, and the bottom tab should still work with the lower radiator bolt.
373548
373549
LHRB
Discussion Starter #3
Removed the upper tabs and the rest of the install was easy. The only thing I am hesitant about is some contact between the metal brake lines that run from the abs module and the radiator guard. I placed some foam between the two parts, but there is still undesirable contact. Pictures to follow.
LHRB
Discussion Starter #5 (Edited)
This pic is from the following thread:
I think I may remove the evotech I installed and trim the screen to avoid the brake lines altogether. The vibration and contact will eventually affect the brake lines.
373576
1 - 5 of 5 Posts
