the fan on my bike isn't turning on. I've read that it is supposed to turn on around 215 degrees or so, but the temp gauge read 230+ the other day. I checked the wiring and everything seems to be fine. Any suggestions?
its either a burnt fan, a bad relay, or bad wiring.
Jump a +12 and a ground wire to the fan and see if spins. That will tell you if the fan is good/bad.
Next trace all your wires to see if something came loose or shorted out.
If you don't find anything, replace the relay
Hey guys on 2000 yamaha r6 I can't get the fans to come on when temp 218. I tested the fans it work fine. And there's no relay for this model and year. Help........Me.......Pls.......
