1 - 9 of 9 Posts
Since I am here in NY, I am told I am required to have a license plate light and one red reflector. Since I will be integrating my turn signals, I am looking for a mount that handles the above but does not offer turn signal holes. What is the cleanest, sleekest it or mount out there?
there's several options. you could get the mount that mounts right under the tail light. that looks pretty clean. also there's a mount you can buy for mad cheap like a custom mount for a few bucks that mounts right above the rear tire. i personally got the swing arm license plate holder that mounts sideways on the side of the rear tire. it has no license plate light or anything. btw i'm from queens
RIDE, SURF, L )VE
you can mount your plate for free. under the tail you will see 2 black clips. pop them out...bend your plate a bit...replace the clips through the two top plate holes. your tail light will provide light, it will be visible, and when a car is behind it will provide the light needed to see it. lots of guys have it, it looks clean, and its free...i did it and have had no problems
Shake & Bake!!
:stupic But I did add an extra LED light so the pigs stay off my case.. :fact
i got one on eBay, very small (in terms of size) comes w/ 3 separate LEDs, so it's pretty bright ... hopefully cops won't complain much about that... i do like the other one but it goes more inside and since you live in new york, you know how cops are in these areas... so i'm thinking what i did is probably the best option
Under construction
Competition werks license plate bracket it sick but will set you back a little. they even come with the light. As far as the reflector goes, **** the system, ha ha.
right, this is the one i wanted to get but i'm afraid that means ticket once a cop pull you over, otherwise i think it's the bad ass fender eliminator
1 - 9 of 9 Posts
