Hello all,
I know what you're thinking, here's another idiot who needs to rebuild his carbs.
Within the last two months, I have pulled apart cleaned and jetted my carbs(factory pro). I even pulled the stack apart as I had to reseal the o-rings in between. The bike started right up and for the most part, was trouble-free. I started with the recommended factory pro specs for my setup.
Here's my current predicament: The bike is slightly rich at idle and somewhat rich between 9500-11500 rpm. I have no issues at partial or even 80%ish throttle, but a wide open pull will cause some slight breakup between the rpm range above. I know air mixture screws help with idle, I have them at the factory pro recommended 3.5 turns out. I have been meaning to lean them out (by tightening them I believe?) but haven't got to it yet. Would my upper rpm issue be consistent with this? I think it may be rich enough that the screws won't be able to lean it out enough. This is when you would switch to needle height adjustment correct? Is lowering the needle into the carb (moving the spacer up) lean the bike out more? The way I understand it is they work somewhat together, the needle sets the range and the screw dials in the exactness.
I don't think it's the main jet as it runs as it should from 11500-16000. Main jets are the recommended 155 outside, 150 inside. The pilots are up to a 40 from a 38, but off idle acceleration is pretty solid. If I remember correctly the screws are 3.5 turns out and the needle is on the third of 5 slots for height. The bike has an OEM air filter (brand new) and a scorpion slip-on.
I have been meaning to pull the tank off and just troubleshoot myself but hoping someone can save me some time.
Lastly, I'm pretty sure I have the tools to the idle air screws, but I am curious, has anyone tried adjusting their needles with the carbs still on(airbox off of course)? Does this work? Already had the carbs out a few times so I would prefer to leave them in.
Thanks in advance
- Nick
Thanks in advance
- Nick
