My R6 is my best friend.
what?
just get a flasher relay... motomummy.com. problem solved.
Discussion Starter #3
i looked for a couple of minutes in the electronic section and also in the "Signals, Flushmounts, Fender Signals" section but i must be looking right at it...
also, i looked closer at both the oem and the flushies and realized that the oem has a green ground wire, making 3 wires, but the flush kit only has 2, hot and nuetral... think i could run a ground wire from the plug to somewhere else and make it think it has a ground?
Thanks for your time,
Chris
Your 2 wire system that you have now off ebay is just a turn signal and off when not turning. You need to get another kit that allows it to be a running light as well or u can just use it how it is. And as for tricking the system you can put in a resistor inline with the power wire i cant remember what size resistor you can look it up. but that will trick the system into not flashing fast.
i personally like mine to flash faster i feel that it just gives it that much more visibility to other drivers who already cant see you in the first place. personal opinion
Discussion Starter #6
actually mine never goes off, its eaither blinking when im turning or on when the bike is on but it only has 2 wires... the 3rd is a green 1 so i thought it was ground...
