1 - 3 of 3 Posts
Just installed my Lockheed Phillips Aero flush mounts and my CA intergrated tail. I also purchased the CA flasher relay. Installed the CA tail and aeros with the stock flasher still in place. the signals blinked faster then normal but everything was nominal, so I installed the CA flasher relay. With the CA relay connected the blinkers stay on instead of flash when I use the turn signal (the corresponding side stays lit). Install the stock flasher relay back in place and it blinks like it should, just a little faster then normal. Sound like a bad flasher? or does the Lockheed Phillips flushies have built in resistors? can't think of any other reason why it would do this.
Most LED lights (flush mounts) do not have resistors but I could be wrong. Sounds like a bad relay to me. Mine flashes fast with my CA and hot bodies flush mounts. I was thinking of adding that relay but obviously only if it works right so keep us updated.
Discussion Starter #3
Just talked with Clear Alternatives, the gentleman I spoke with was certain I got a bad flasher, have to send it back for a good unit.
1 - 3 of 3 Posts
