1 - 5 of 5 Posts
I replaced my stock turn signals with McCoy Motorsports flushmount turn signals the same day I replaced my stock tail with an integrated plug and play. When replacing the turn signals I used OEM connectors to make them plug and play also.
After having them all hooked up and attempting to see if they work I ran into a problem. When the bike is on they stay lit like running lights and when I activate the signal they do not blink at all, just stay lit. The tail light works properly with signals and everything.
Now is an I an idiot and this an install problem? I connected red to red and black to black with the signals and the OEM connector I bought, or is this a resistor issue with the LEDs drawing less power and messing with the stock connector? Any help would be much appreciated. Thanks.
Sounds like you need a new turn signal relay. Did you replace the stock one?
R-Sex
clip the constant "hot" wire on your flushmount side an it'll fix your problem. most flushmounts have 3 wires. (1 constant hot/running light, 1 signal, and 1 ground)
1 - 5 of 5 Posts
