Hi everyone,and dry asphalt to all of you.
I'm writing to get some help with my little project,i got a 2002 R6 that took some beating,therefore needed some work, including some front side rebuilding, cables and wiring redoing,and so on.I got a bit stuck while redoing the passage for all the cables and wires,since between the front support,horn,air intake and so on not much space to play.Also, while redoing the cable way for throttle, clutch, idle, and so on, got a bit lost in which cable should go through where.Therefore, I ask the owners of such beasts if they have pictures taken while during such work,so that I can figure out everything.
Thanks in advance, and clear skies to everyone.
