Hello,
I rebuild front brake master cylinder and also both calipers with new seals.
When Im trying to fill oil back and bleed the system, air is getting out and I can see little bit of oil going out in rubber tube but pistons doesn't even try to move to squeeze brake pad. No pressure
I spend pumping over 2h both and I have no pressure to pistons but oil does go through.
There is no leaks.
There is no leaks.
