41 - 60 of 84 Posts
re: FS: 05-15 R6 Stock & Aftermarket Part Out
Aloha, yes I am willing to ship the items listed to you, as long as you cover shipping charges. Please private message me your shipping address, so I can get you price quotes. Mahalo
Hi
The shipping address for the requested Items.
Unit 49 Villa Jene
225 Hendrik Street
Wierda Park
Centurion
Gauteng
South Africa
0157
Parts List:
1. Complete forks left and right
2. lower tree with stem washers and nuts
3. upper tree clamp
4. Gauge Cluster
5. Gas Tank
6. Left Gas Tank Bracket
7. Rear Gas Tank Bracket, excluding the bush and rubbers
Please can you send me a quote on the list of parts and the shipping cost to South Africa
Discussion Starter #42
Hi
Unit 49 Villa Jene
225 Hendrik Street
Wierda Park
Centurion
Gauteng
South Africa
0157
Parts List:
1.Complete forks left and right
2.lower tree with stem washers and nuts
3.upper tree clamp
4.Gauge Cluster
5.Gas Tank
6.Left Gas Tank Bracket
7.Rear Gas Tank Bracket, excluding the bush and rubbers
Aloha, I will take the items to USPS and get a quote for you tomorrow. I have the following items from your list.
Parts List:
3.upper tree clamp
4.Gauge Cluster
Mahalo
Hi
Just to confirm, what model bike where the forks removed from, as I see you had upgraded your forks on the 2005 R6 with later model forks.
Forks from a 08-16 will fit on my R6.
Same for the gauge cluster, can you PM me a picture with part number so I can confirm if it will work on my R6. 13S ECU
Discussion Starter #44
Hi
I will have photos and information sent to you later on today. Mahalo
Do you have an engine oil pump cover by any chance? For the r6s
i can't post pictures directly here because I'm new, but heres a link. Look in the first picture, it's the thing that has a nasty scrape:
imgur.com/a/GQ5X84w
Discussion Starter #56
Updated list.
1. Frame comes with clean and clear title in hand, no damage, $1000
2. Upper stay bracket OEM, no damage $75
3. Rear fender, no damage $15
4. Rear shock, no damage $50
5. Rear caliper and brake line OEM, no damage $25
6. ASV c5 front breakable lever, no damage $45
7. Stock left and right side rear sets complete OEM, no damage $100
8. Swing arm OEM, no damage $65
9. Rear axle bolt OEM, no damage $10
10. Power commander III, PC3, no damage $125
11. Windscreen, no damage $10
12. Kick stand OEM, no damage $15
14. Complete lock set, no damage $125
15. Front rim/tire without rotors and is straight, $150
16. Rear rim/tire and without hub and is straight , $150
17. Front rotors no damage, $100
18. Sprocket hub no damage, $15
19. Stator and cover, cover has scratches, but no cracks, $100
20. Crg c5 front left and right levers, no damage $65
21. Ecu no damage, $125
22. Air box no damage, $20
23. Headlight no damage, $100
24. Front forks no damage, $250
25. Lower and upper triple tree no damage, $75
26. Front calipers no damage, $85
27. Tail light no damage, $15
28. Complete right handler without master cylinder no damage, $65
29. Complete left handler no damage, $65
30. Gauge no damage, $100
31. Rear passenger pegs no damage, $65
32. Left and right ram airs no damage, $50
33. Radiator with fan no damage, $80
34. Mirrors no damage, $25
35. Chain no damage, $15
Discussion Starter #60
Here is a updated list.
3. Chain no damage, $15
10. Mirrors no damage, $25
20. Radiator with fan no damage, $80
I have also broke down the motor.
1. Crankshaft
2. Cams
Etc.....
41 - 60 of 84 Posts
