1 - 20 of 43 Posts
Trying to off the rest of my R6 parts I won't be needing.
Located in Brighton/Metro Detroit. Shipping isn't an issue and usually goes out the same day, or next.
Located in Brighton/Ann Arbor, MI.
Any issues/damage are noted below.
Prices are all OBO, within reason.
2006-16 Parts
Frame sliders - I think they are Vortex - no damage - $50 shipped
2006-07 R6 parts
Frame - clean title - $600 plus shipping
Fuel tank - Nearly mint - $400 shipped
Forks - Straight - No issues - Black - $200 shipped
Subframe and tray - $145 shipped
Radiator w/ fans - $130 shipped
Lock set - Ignition/Gas Cap/Seat Lock - $100 shipped
Clip ons - $65 shipped for both
Swing arm - Clean, no damage - $50, shipping extra
Wire harness - $80 shipped
Fairing stay - $45 shipped
Upper and lower triple set - Staight, no issues - $120 shipped
Rear sets with shift rod - $100 shipped
Front calipers - $100 shipped
Rear brake master, line, and rear caliper - $50 shipped
ECU - $95 shipped
Ignition coils (Set of 4) - $45 shipped
Headlights - $100 shipped
Rectifier - $30 shipped
Mirrors - $40 shipped
Air box - $40 shipped
BMC air filter (2X) - Like new - $40 shipped
Horn - $10 shipped
Stator - $45 shipped
Fuel pump - $75 shipped
Rear shock - $50 shipped
Passenger pegs - $45 shipped
Switches - $50 for both, $30 each
2008+ Parts
Subframe and tray - Straight - $160 shipped
Mirrors - $50 shipped
I'm sure I'm missing some things, so if it's not listed, ask and I may have it.
**Engine parts**
I have an 06, 07, and 08 that have various issues.
06 - Runs, but needs a valve adjustment and cam chain tensioner
07 - Spun bearing
08 - Threw a rod, hole in the block
Tons of good parts on the three engines, let me know what you need.
Sent from my XT1650 using Tapatalk
What color are the passenger footpegs and do they have any damage? Need some for my 09 r6.
Sent from my ONEPLUS A6013 using Tapatalk
Need a good cylinder head. Prefer to have cams and caps with it. Thanks
I wouldnt entertain buying one without the caps...lol.
Unless yours is completely destroyed... its less risk to rebuild your own.
Components are going to run north of $2,000 if you want minty high performance fresh. About $135 per valve, spring, collets, etc. X 16 :surprise:
Good point on the caps, just figured I would make a point of it. Have two sitting in my garage; one is cooked/warped and the other has the bore on the exhaust cam deformed. Not sure what caused it, but the lower half of the exhaust journals are rolled over (oil starved? could have been that I didn't plastigage when I swapped out the cooked head). Just finishing putting new rings in, was putting on the head and trying to set timing but couldn't turn the motor over. Turned over fine without cams in and upon further inspection found the journals mashed up. Not sure how a machine shop would fix it.
I've come to terms that I'll never be able to afford a new / rebuild a cylinder head.
I might start with V&H, KWS, or Starr performance to see what your options are.
Ive seen some of KWS's repair work on broken OHC cylinder heads... you couldnt tell anything was done. And they were cast parts.
1 - 20 of 43 Posts
