1 - 12 of 12 Posts
Parting out 2008 Yamaha R6 Race/Track Bike:
  • Prices do not include shipping.
  • Located in Chicago suburbs.
  • Big items such as engine and frame prefer local pickup.
  • More pictures available - site has a limit.
  • Please PM me with questions.
Forks with RaceTech 25mm Cartridge Kit and Extended Fork Caps - $1100
9.5/10.0 Ohlins springs for a 9.75 spring rate
RaceTech G3-S Rear Shock - $800
607 spring, piggyback reservoir, Lo/Hi speed compression, rebound and ride height adjustment
Ohlins Fork Springs 9.0 N/mm - $80
Shock Spring 600 lbs - $80
Front Brake Calipers - $120
Spiegler Stainless Steel Front Brake Line Kit - $80
Front Rotors - $100
Rearset relocation plates (1" or 1.25" down and back) - $100
DynoJet Quick Shifter Sensor (push) - $150
Woodcraft Clipon Clamp Set Only (no bars) - $100
SuperSport Armour Bodies Tail (tail, seat bracket, seat) - $140
Right fin ground down - see pictures
Engine Is Sold! More Parts Added Below.
Discussion Starter #2 (Edited by Moderator)
More pictures below
Discussion Starter #7 (Edited)
Engine is sold. Adding more parts.
Frame with Clear Title - $1000
Rear Wheel with Rotor and Ariete 90 Degree Valve Stem - $240
BMC Race Air Filter - $50
Gauge Cluster - $150
Some hazing on the face of the cluster. Couple tabs are broken on the back side. See pictures.
Fuel Tank with Cover Fairing - $340
Barely visible dent on left side and rash on the right side. Both can be covered with tank sliders. Vortex Gas Cap extra. See pictures.
Fuel Pump - $75
Vortex Gas Cap - $70
Airbox - $170
Woodcraft Frame Sliders (only 1 puck) - $40
Regulator Rectifier - $35
Radiator Reservoir Tank - $30
1 - 12 of 12 Posts
