Forum Moderator
Selling my Woodcraft Gen II tire warmers:
Redesigned dual temp switch- Our new Dual Temp switch is the direct result of customer feedback. The new recessed switch is surrounded by a tough plastic case protecting it from impacts. This design is much tougher yet the temperature is still easily selected by a gloved hand.
New Thermostats - Our new thermostats hold tighter temperature ranges and are more durable than ever, guaranteeing a perfect heat cycle every time.
New Construction- We went through the entire warmer from end to end and upgraded every seam. Our new warmers are double stitched with a tough nylon thread ensuring they look good and will last through years of abuse.
Key Features:
Even Heat Distribution - The small gap heating element leaves smaller spaces between the coils, ensuring the whole tire is heated evenly, virtually eliminating cold spots.
Great Insulation - Our special insulation is extremely efficient allowing us to keep the warmer construction thin while still providing great performance. You will love how easy the low profile design makes installation and removal of the warmers.
Side Curtains - Our fleece side curtains eliminate the #1 cause of heat loss by protecting the tires from side winds. In many cases we have seen up to a 15 degree increase in rim temperature compared to warmers without them.
Easy to install / remove - A large one piece velcro strap secures the warmer to the tire without hooks or cords getting in the way.
Durable - We used only the best components and subjected all internal connections to rigorous tension tests to be sure these warmers are built to last.
LED Indicator Light - Pick your tire temp with the flick of a switch the display 'on' light is red and turns to green when the tire is at temperature.
Voltage: All Woodcraft tire warmers are designed to run off a 120V power source. Generator users will need 1000 watts minimum to run a set.
These are quality warmers in great shape. You can buy the cheap stuff, but only get a season before they burn out.
Selling my Teknic Kangaroo Xcelerator Race Suit with Astars Cool Max Under Suit. Suit is a size 42
Full perforations for optimized airflow and cooling effect.
Combined kangaroo / 1.4 mm top-grade drum dyed Brazilian cowhide construction.
1.0 mm Italian kangaroo provides same abrasion and 30% less weight than conventional cowhide race suits. Very supple from new requiring very little break-in time. Linear fiber alignment is abrasion-resistant yet flexible.
TASC multiple row stitching provides extreme abrasion and tear resistance in the most critical of areas.
Safety Wrap leg system eliminates possibility of seam bust, reduces weight and increases strength.
Seamless Full Motion arm and leg systems, with expansion panels of Kevlar, allow flexibility and unimpaired movement.
Double-layer reinforcement of cowhide in all abrasion areas and curtain layer behind rear stretch panel for added protection.
New 3D air-mesh combined with the 3M Scotchguard moisture-wicking mesh liner to maximize airflow between rider and shell and provide a better cooling effect on the body.
Improved pre-curved elbows and knees with forward rotated arms and hips for ergonomically correct fitting.
All CE-approved Teknic armor is manufactured and tested to the strict European EN1621-1:1997 safety standard.
CE-approved Teknic Airblade injection-molded shoulder armor. (Backed by 8 mm memory foam).
Knox CE-approved multi-position armor system / with VELCRO brand hook-and-loop fastening in the elbows and knees provides an adjustment system allowing personal and correct positioning of armor.
Dual compound nylon / aluminum elbow sliders protect critical seams and improve abrasion resistance.
Hip padding (6 mm memory foam) in pockets that are upgradeable to Knox "Flexiform" CE hip.
Aerodynamic hump, for added airflow and whiplash protection.
Pockets for optional chest armor.
Memory foam protection in collarbone, chest, thighs, tailbone and lateral impact points for additional protection.
Chest and back protector are included built-in.
The suit has been well taken care of. Always stored in a A/C closest. It does not smell and has no rash or tears on it. It's never been down. other than being a little dirty it's in top shape. I'm almost 6ft and 155 to 160 and it fits great.
Selling my Nexx XR1.R full face racing helmet. Size M
Tri-composite shell with organic fiberglass, carbon and Kevlar
DOT and ECE approved
Ultra light weight helmets that weighs from 1300-1350 grams
Anti-scratch shield with ready pin locking system
Ergo padding system that allows a perfect fit of the helmet in different head shapes
Includes clear and smoke visor
No nicks or scratches
Includes extra padding for fitment
No foul orders or smells
Well taken care of. Always stored in A/C closet
Price for the warmers are $175.00 shipped {Warmers have been sold}
Price for the Teknic Suit is $450.00 shipped
Price for the Nexx XR1.R is $175 shipped
Shipping will be the cheapest way {Probably Parcel Post} unless you want to pay for more expedited shipping. Due to my Job hours I can only ship on a Friday or Saturday. You can text me with at 863-four one four- five o ten o
