1 - 3 of 3 Posts
Hello everyone!
First of all I want to say thank you to the FTecu Support (Kent) !
I am trying to understand the FTecu software and flash it with the correct settings.
I don't have a lot mods on my bike, I have only the Akrapovic Header and the Akrapovic Slip on (Exup valve).
I downloaded the unrestricted file on FTECU software.
Do I need disable the AIS ? Do I need to put the Exhaust Smog Block off plate?
Also I would like to add a BMC filter ....any advice will be appreciated!
thanks,
Flavio
Hello everyone!
thanks,
Flavio
You need to do the smog block offs and disable the AIS
Sent from my SM-G930V using Tapatalk
no. you don't. it does nothing for the bike. the only reason you'd block them off is to get an accurate reading for an AFR meter and a narrowband O2 sensor used in a auto tuner. but blocking these off are absolutely not required for any kind of performance reasons. it doesn't even stop popping like everyone claims.
1 - 3 of 3 Posts
