1 - 3 of 3 Posts
My gas light on my 00 R6 is randomly going on, my tank is full but it goes on then goes away. Where can I start looking?
Also my tach pulsates kind of with the revs in idle. I notice this only at night I guess because it's the light pulsating. Is this normal?
THanks
UnZUnDUnR
The light is probabaly the low fuel sensor(in the tank) going bad, my guess.
If the light is pulsating it could be the stator.Not supplying enough current.Are all the lights pulsating?What is your idle speed?Too low an idle can cause low current output.If the idle speed is correct.Then it could be the stator malfunctioning too!If it does this even with the light off.Then maybe its the fuel system(pump, injectors,plugs,coils).
I had the same problem on my 2007 R6S. I thought originally it was a bad fuel level sensor but what it ended up being was a loose connection under my gas tank so I would recomend checking that out...
1 - 3 of 3 Posts
