If you know someone with a plastic welder have them to fix it. They also have plastic repair expoxy at auto parts stores.
I'd agree with that being your best bet. Look around and get information on it. There are millions of how-to's on the net.If you know someone with a plastic welder have them to fix it. They also have plastic repair expoxy at auto parts stores.
BUMPit might be easier to just get a new bottom fairing i would check on here or ebay. because after you fix it with epoxy or bondo your still gonna have to get it repainted.
Sweet man ill let you know ...thanksNot Hard at all...Just go to the Parts store like scooter said. I have used a two part, or they sell a premixed tube of plastic repair. Just make sure and sand the area around the damage really good with 80-120 grit to give it a good surface to bite to. To ensure a proper repair i always spray some plastic adhesion promoter right before you apply the repair. This will prevent it from chipping out if the panel were to flex. If the crack goes all the way throught the back side of the panel then you would want to prep and repair both sides. Finish by block sanding it smooth until you are ready for some primer. High build primer will cover imperfections and you can even wet sand primer with 600 grit to get rid of the orange peel before you top coat. Shoot me a Pm if you have any specific questions.
