1 - 5 of 5 Posts
Ya so my turning signals and gauge cluster light is out. I've been trying to figure out what is wrong with my HIDS but I don't have much time on my hands to sit outside and mess with stuff. I'm pretty clueless on why my turning signals and gauge cluster is out, any idea guys?
Check fuses, also what type HIDs are you running (35W or 55W), if 55W you need a relay.
disconnect HID, check if gauges turn on, and signal lights working correctly. If everything checks out with the HID disconnected, trouble shoot HID wiring connections (is something loose? Is a wire being tugged?), and the HID system itself. (do you hear clicking sounds from the ballasts?, swap ballasts to see if it might just be the low beam ballast that failed.)
I'll check the fuses and everything tomorrow afternoon. Thanks, I'll keep ya'll informed.
1 - 5 of 5 Posts
