Wow thanks for all the info, and the offer for the help!:toocool::toocool:I run the factory pro 1.1 ti kit, or something along those lines. Most favor the Factory pro kit. Lots of people like the Ivan's jet kits also. The factory pro customer service is excellent. The dude knows the bikes very well, and I've even heard of him sending people different jets possibly for free to correct whatever the issue was.
The link in my sig has all the instructions and pics on how to do it, etc also.
I'm finding in the colder weather I'm running a hair lean. I'm over 1000 feet above sea level tho, and I have velocity stacks, and run almost no oil on my oem air filter too, and have the HR1 which flows way more than any other slip on.. Regardless, there's your info.
Honestly tho, you don't need to ever buy a jet kit for ANY bike. All you need to do is order the main jets (They sell em all over the web on MAD sites), and you can shim your factory needles, which is supposed to be the best method anyway. You could save like $100 going this route man.. I was just on a buying frenzy so I dropped the loot. If you want I can help you find all the stuff you need, etc since i need to get it all or most/some of it for myself anyway.
I don't know what the dynojet kit is like, but generally they give you a starting point as far as the needle clip, etc. They should include some basic info on how/what to do if the bike bogs, or wheezes, etc..Oh and the kit comes with instructions, but does it tell you what to run all the settings at ie (float height,needle clip setting,and mixture screw setting)? i figure it's different for everyone...
Ok thanks for the info i will post all my stuff when i get my jet kit.I don't know what the dynojet kit is like, but generally they give you a starting point as far as the needle clip, etc. They should include some basic info on how/what to do if the bike bogs, or wheezes, etc..
What pipe do you have? Stock air filter? This makes a huge difference.
Also, It's probably hot there a lot. What's the average temp? Here it can be in the high 90's or in the low 60's this time of year..
Generally I'd suggest starting 2.5 turns out on the pilot screws and the needles 2 lines from the top of the needle. It's a good starting point. There's a carb settings thread. Make sure you post up your settings and results. We are tryin to get a decent thread together with a bunch of info. Also post up the jet sizes.
And the float height info and specs are in the service manual
Everyone says the stock filter is the best. It's only gonna come with one set of jets probably, so try em both, but I bet the OEM is gonna be the better of the two. There's some turbulence issues I think with the aftermarket ones. The guy at factory pro and a mechanic who used to race the carb'd R6's both told me to go OEM.. Try em both and keep us posted! Especially on those jet #'s, etcOk thanks for the info i will post all my stuff when i get my jet kit.
I have a yoshi rs-3 slip on, and a k&n air filter which i wanna switch to a stock or uni which ever is better....
Oh and the average high is 83 and low is 63
Thanks again for the info. I will keep you guys posted in that thread you named above.Everyone says the stock filter is the best. It's only gonna come with one set of jets probably, so try em both, but I bet the OEM is gonna be the better of the two. There's some turbulence issues I think with the aftermarket ones. The guy at factory pro and a mechanic who used to race the carb'd R6's both told me to go OEM.. Try em both and keep us posted! Especially on those jet #'s, etc
