so i got bored at work over the past few weeks and decided to change some of the stuff on my bike sence i had the extra parts
and shaved the hole on the under tail
i had the stripe go all the way onto my black loswers when i had it i just need to order it and ill put them onhow did you shave the hole. im interested in doing the same on my bike.
I like the white. It looks more racy. I would continue the champions stripe though. But that is it. Looks nice.
i thought about doing the lowers yellow but that yellow is a very expensive color so maybe this winter ill seeI like the lower. I wonder what it would look like if it were yellow? Anyhow, nicely done.
thats what i wanted to know. didnt know what you used as a filler. and the glue is from lord fusor right. we use that stuff at school. i go to uti in the collision program. also did you paint it as well or did you take it to someone. cuz you did really clean work. props to youi plastic welded it into place and covered the black side with fusor glue its real strong stuff
for filler i just used a little bit of a light filler not to much and yeah i did all the work myself paint and everything. if your going to do it grind the whole ared like 1/4 of an inch around the area on the out side and inside and then plastice weld and glue. then i used bondo on the out side to get the shape the rest of the way then primer sand and then went on to painting itthats what i wanted to know. didnt know what you used as a filler. and the glue is from lord fusor right. we use that stuff at school. i go to uti in the collision program. also did you paint it as well or did you take it to someone. cuz you did really clean work. props to you
yeah i have blinkers i have the CA intergrated tail light and the plate is held on by the 2 black push pins on the bottom under the tail you can see them when you look and they are the perfect space apart from eachother and they wont fall off i have had this set up for over a year now with no problemsDo you have rear blinkers??? I want to mount my plate up underneath also but I need to find a place for the blinkers. How did you mount your plate? Thanks for any info you are able to give.
