1 - 5 of 5 Posts
Somebody tried to steal My 04 yfz R6 and so my wires are burned under the ignition. I got power when I turn over the key. I can hear the fuel pump. No blown fuses. Idk what to do. Help.
YZFR6... ooodles of HP
Check every terminal for a short to ground before anything else!
Gotta make it obvious that "you aren't going to ride this anywhere" with a caliper lock.
Ultimately security is a layered approaching, including location and time.
First thing you prob need to buy is a new ignition barrel with a new key. Then chase every wire to look for cuts. A no start could be the pickup rotor or cam position sensor. Neutral light is a sensor down behind the starter in the middle of the engine if I remember correct. All things usually jacked up in a theft since you can just jump power to them to start the bike. No blown fuses means it’s prob not hot wired ( or at least hot wired wrong ) and fuel pump priming is a big positive. Update if you get a new ignition and run into the same problems
1 - 5 of 5 Posts
