1 - 4 of 4 Posts
So i think my head is commin off the motor anyone got a online link for a manual to this motor i can print off mainly for torque specs
Stunt Rider
Why?
Ya wheelies is garbage!
http://www.r6messagenet.com/forums/...254-r6-service-maintenance-repair-manual.html
Make sure you keep all your buckets and valve pads in order or you could completely fubar that valve train when you go to crank it back over. Also make sure you don't swap out the intake and exhuast cam shafts. The Exhaust has a machined lip/ring with a void in it that the cam position sensor reads. You replacing a headgasket? If I were you I would check the valve clearance and go a head and get that done while you are at it too. If the valves get adjusted, I'd then do a TB sync and that thing should pull great on idle.:YEA
1 - 4 of 4 Posts
