1 - 13 of 13 Posts
Mario J's Apple Juice
Prepping my friend's bike for his first track day and was wondering if it's required? Exhaust is pretty close to the fiberglass. I've heard you don't need it unless you want to protect the paint since it bubbles up.
I have a stock exhaust and, althouhg the bodywork will fit, I was told by Armour Bodies to put heat tape because it's tight around the cat.
Race fairings are easier to put on and off, he (and myself, if have to) could remove the belly pan between sessions or at least during the lunch break.
UR B-hind Da 8 Ball
Well, first of all, fiberglass won't melt. The paint might distort or bubble and over time that area of the fiberglass might get slightly brittle from the heat. A package of the heat shield will run about $20 at an auto storeand it would be enough to do two pans. You wouldn't need to cover it as thoroughly as you would street plastic
Official Noob Greeter
I would or the fiberglass can bubble, deform, and even separate.... Especially if you plan to do some decent paint.
Parts Pimp
My belly has been fine all season with no heat tape or anything. I will consider putting some on there, but it's one more thing to worry about. It gets wet, then dries and shrinks and peels back over time, then you have glue getting on the pipes and smoke, etc.. :nono
My 05 header swap bubbled on me at the front of the lower pan.
Heat shield helped after the fact no problems since but lol still havent fixed the bubbles yet.
Agg,
You said your Leo touches? I had seen in other threads that this at least used to be a problem burning through with the full Leos w/ Armour Bodies (I even saw some cut a spot where the upper header touches and then make a fiberglass bubble to seal the pan). I called AB who said that was an issue with early designs and has been resolved. I want the Leo/AB combination but if the Leo has problems I guess I'll go Akra... Thanks for your help
Make good choices.
I would say you heard correctly.
...I called AB who said that was an issue with early designs and has been resolved. I want the Leo/AB combination but if the Leo has problems I guess I'll go Akra... Thanks for your help
So do you not believe them when they said it's been resolved?
Get some thin aluminum sheet from a local hardware store.
Bend it to fit the shape of the bottom of the belly pan. Drill a hole at each corner and rivet it in place. Never peels and is effective.
1 - 13 of 13 Posts
