1 - 4 of 4 Posts
Today i could not get my six to shift right. I don't have any problems taking off in first so the clutch is ok. I can shift into second but then third is hard to get in to and the rest almost impossible. Its like i move the lever up with my foot but it doesn't click into gear. What should i check? Any ideas?
I had the same problem after I changed my shift lever.
There is a rod you can adjust that connects from the shift lever to the gearbox. If your lever is set too high, then you can only shift a few gears before the lever reaches it's limit.
1 - 4 of 4 Posts
