1 - 3 of 3 Posts
ok i started noticeing a weird noice that is maybe coming from the front tire. it is a squicking noice that is sort of anoying. i was thinking that it might be that the front axle is not lubricated but i wouldnt make a difference. i have notice that it happens more when i turn. any input on the matter. could it be the brakes. or what????
thanks
Phi Phi K A
Did you recently install clickity clackers? ..............j/k
Try tightening the fork axle bolts on the bottom of the forks that face forward. If that don't work. Dismount the wheel and clean and lube the axle and axle nuts an the spacers. Also clean and lube your calipers. If that don't do it, then it could be either a worped rotor or a loose headbolt or bearing. In other words, in could be anything.
1 - 3 of 3 Posts
