slow guy
Remove the 4 button head cap screws underneath and the 2 plastic push pins. Then pull your passenger seat off. Remove the push pins for the tail light the button head cap screw for the upper portion of the rear tail. You should be able to pull the under tail out now, carefully spin it around so you can remove the cable from the seat lock.
do i have to remove the screws off the license plate?
