1 - 11 of 11 Posts
Hey guys... yes im a noob... so i was taking of my hand grips and now i can't get the end to screw back in.... like the little black metal part of it... when i push the screw in it go right through like nothing is there to screw on to. it use to be on tite but after i took it apart it can't seem to screw the end back on.... can someone explian :?:
THanks
Get a flashlight, and see if the nut went up into the bar.
I had to recover a condom like this once...
No seriously, Maybe the female part of the bar end got sideways or went up into the bar.
When the bar-end came off was there a piece of rubber on the end that the screw went into? It should be about an inch long. if not, you can look into your bar, and see the rubber piece...if it is in there, it needs to come out. The screw goes through that rubber to a nut, and when you tighten it down, the rubber becomes squashed in the bar, and is tight. If the rubber is still in there, then good luck getting it out. The nut is loose, and on the other side of that rubber piece. When you take the bar ends off, just loosen them up a little bit, and pull. If you loosen it all the way until the screw comes out, your screwed...literally.
that's really....different, there, Tex.....uhm. how exactly did the condom get in the bar end? :mrgreen:
hahah thanks for all the replys... i had to pull the rubber part out and get the nut... and super glue the nuts to the rubber part and stick them back into the bars.... that way i can screw it back in with out it "GOING SIDEWAYS"...
1 - 11 of 11 Posts
