1 - 10 of 10 Posts
Ok guys so I'm technically inept. I recently started renting out an inlaw apartment. It's connected to the landlords house. I looked around the house and can't find any Ethernet ports or whatever they are called. I play ps3 and the signal is horrible since the router is in his house. So my question is..... Is there anything I can buy to make the signal stronger on my side of the house? Or can I buy a router of my own but still use his WiFi??? Please throw out any ideas or solutions I'm horrible with this stuff haha
Make good choices.
Easiest solution (and free) to try first is to ask him if he can move the router so it puts out a stronger signal to your place. Consider the number of walls, the angle the signal has to travel and the material inside them in between your PS3 and his router.
I feel for you. A spotty internet connection can be insanely frustrating.
Make good choices.
The ideal solution, in my opinion, is to run a hardline.
This would require working with the landlord to scope out the situation and see if it's practical and wont do any damage that he isn't comfortable with. If the house is old, the cable installer probably had to just run the coax around the house and through the walls. If this is the case, you can use the existing holes to run a long Cat5 cable (cheap!) from his router, along the house and into your place where you would have a router of your own acting as a repeater (same network and everything). Hard wire the PS3 to this and you would have the fastest, most reliable connection available to you. Again, this may not be practical/possible.
Make good choices.
You could try that. It may work because it probably has much better wireless connectivity than the adapter in your PS3. In other words, that product may be able to do more with your weak wifi signal than the PS3 can on it's own. Probably a crap shoot though. I've never used one of those, so I don't know how hard it is to set up. Looks like you can get a used one on Amazon for about $20 so it may be worth a shot.
Mexico lindo
If you share the same electrical system as your landlord you can get a PLC solution that should solve your problem. The solution is simple and comprised of 4 pieces: two adapters (both have ethernet ports and plug into the electrical outlets) and two ethernet cables, that's it.
How to use it:
1. First adapter you plug in the electrical outlet where the router is and connect the adapter to router via ethernet cable (in your case your landlords house)
2. Plug in 2nd adaptor to electrical outlet in the room where your PS3 is and connect it to PS3 via ethernet cable.
3. You are done.
The internet signal is carried through the electrical system in the house so as long as you are on the same electrical system as your landlord you should be good.
Here is a link to D-Link product that gives up to 600Mbps: http://www.dlink.com/us/en/home-solutions/connect/powerline/dhp-601av-powerline-av2-600-gigabit-starter-kit Link has good diagrams to show how it works.
Hope this helps
..just realized i bumped an old thread... sigh.. sorry.
The powerline converts are nice but they work best on updated electrical. There are a lot of factors to consider when using these. The one on his side may go back to a different breaker than on your side, that counts as a distance factor as well as introducing potential for interference and even having it on the same breaker, it can be impacted by what is on your line already. You may buy them and have no issues but you may find poor performance and stability issues.
Your best bet is you run a cat5e from his side to your side and buy yourself a $20 Ethernet hub. If you want more than one device on cat5e then this will suffice... but you aren't limited to plugging the cat5e into a router and setting up your own SSID.
When I first read your post I considered a repeater but if you already have signal issues the repeater isn't going to help much, unless you can find the perfect placement of the router on his side like someone else had recommended.
1 - 10 of 10 Posts
