The two wires that go into bullet connectors are for the license plate light. Just pull them apart to disconnect them. You can sodder the two or strip and tape, etc. Or if you find another bullet connector, it'll slip back in. I couldn't find one, but the VFX fender eliminator had the right size bullet connector for the license plate light.
The ones that go into the gray and black plastic connectors are for the turn signals. I think black is left and gray is right, but I can't be sure. Just unplug on and turn the blinker on to see which one's which. To separate the two connectors, there's a small tab on the female side (the one that receives the other plastic connector). Pull up, and you should be able to disconnect the two. Before i got an integrator, I cut the wire on the other side of the black/gray connectors and used a hardware store connector to connect the stock wires with the aftermarket turn signal wires. Two for two. I didn't color coordinate. I just used one wire for one wire. It worked just fine.
